Where are you building & what climate zone? Are you venting the roof? If so, how? If not, why not? Sounds like you have two rafters; if there is a space between them the batts will not fill it, so you'll be much better off with a blown in product - either cellulose or fiberglass. (Of course IMO fiberglass is an old and bad technology for many reasons; its only used because it is cheaper initially, and ultimately you get what you pay for.) if you use t&g under the osb, you should seal all the joints in the osb; t&g is notorious for leaking air. |
