Recirculating Range Hood Along With ERV
Last Post 02 Feb 2012 08:13 PM by Litawyn. 47 Replies.
Page 3 of 3 << < 123
Amazer98User is Offline
02 Feb 2012 01:37 PM
I would encourage you to use a hood that vents to the outside rather than one that recirculates dirty/smelly cooking exhaust through some filters. You will never regret using a system that kicks the dirty stuff outside.
We have a fairly basic Vent-a-Hood, which works great. It is only 30" wide-- customer service rep at Vent-a-Hood suggested that we select the dual-fan option, but I decided to use just a single fan... and it is more than adequate.
I looked at those options for heating outside air and discharging it into the kitchen to make up for exhausted air-- they look clever and will no doubt do the trick. You don't even have to exhaust them into your kitchen-- you could put them anywhere in the house, so long as they turned on with your range hood, right?
LitawynUser is Offline
02 Feb 2012 01:39 PM
Amazer98:
If you follow the thread, you'll see that I decided to switch over from a recirculating hood to one with an inline blower that vents to the outside.
You are correct about the make-up air system.    It can bring air into whichever part of the house you'd like to locate it.    I'll likely have mine installed in the basement.
John
02 Feb 2012 01:44 PM
Posted By Litawyn on 02 Feb 2012 01:39 PM
Amazer98:
John
Oops, I must have missed that comment as I skimmed over the earlier posts.  Anyway, I think you made the right decision. BTW, what are you using to heat your house-- a propane modcon boiler or oil burner?  Radiant heat?
02 Feb 2012 01:54 PM
Posted By Amazer98 on 02 Feb 2012 01:44 PM
Amazer98:
The house will be heated primarily by an efficient wood pellet boiler.    This will be backed-up by an 11,900 Btu heat/cool pump that will also be providing A/C when needed in the summer.    In the winter, I'll also be relying on a south-facing soapstone floor in the dining and laundry rooms that will be absorbing passive solar heat in the daytime and heated up when necessary (at night) by a small electric radiant heat system beneath it.    Since the pellet stove will be at one end of the house, I wanted a way of keeping the opposite end of the place warm on a really cold night so I could keep the heat in the place balanced at a minimal cost.
You'll find the specs and floorplans for the place here:  www.litawyn.com
John
02 Feb 2012 02:03 PM
Very pretty design-- I like the front gable above the porch!
02 Feb 2012 02:14 PM
Posted By Amazer98 on 02 Feb 2012 02:03 PM
Thanks.    I won't be painting the place orange for sure, but it'll still have the same overall design and proportions you see in that photo and be around 1/3 larger.
The original house is 874 sq ft; my modified version will be 1,197 sq ft over a full basement.
John
02 Feb 2012 02:22 PM
That's a nice part of Maine you're living in-- I've sailed all around Penobscot Bay with a old friend who lives down in Falmouth. Love it up there!
It's a beautiful part of the country.    I feel fortunate to live here.
John
People Online People Online: Visitors Visitors: 163 Members Members: 0 Total Total: 163
