hot air system has fresh air intake into return plenum
Last Post 04 Feb 2012 09:23 AM by hewaschuk. 3 Replies.
hewaschukUser is Offline
02 Feb 2012 01:47 PM
EditEdit QuoteQuote ReplyReply AlertAlert
My daughter and her husband live an hour's drive from Edmonton, Alberta.  Winter temperatures are frequently -30 and even -40 degrees F.  When we were making some changes to the duct work in the smallish one story house, built in 1955, (they converted 3 small bedrooms into 2 larger ones), we noticed that there was a 5" duct bringing outside air into the return plenum.  Apparently this is required by modern codes,  (not sure when this heating system was put in, but probably not  when the home was built).  I can see that when the dryer and/or the bathroom exhaust fan were working that an outside air supply would be a good idea.  However, bringing in too much outside air would cause the heating bill to be higher than necessary, especially at - 35F.
I presume that the damper in the 5" fresh air line needs to be adjusted to prevent excessive air from coming in.  The question is, how do you know where to set the damper?  Would taping a plastic sheet over an open window and watching for the plastic to be in a neutral position (i.e. neither bellowing in nor out) with the clothes dryer on, be a guide when adjusting the damper?
My daughter lives in a small town far from any city where expert help might be available.
Is there an easy way to know where to set the damper without any fancy equipment, or do we have to bring someone in from Edmonton?
SkyHeatingUser is Offline
03 Feb 2012 04:56 PM
You might want to look into adding an HRV or ERV depending on your location. I do not know much about heating with that low of temperatures. An HRV will take heat from the air in the house and put that heat energy into the incoming air while ventilating out the old stale air.
Check out companies like Venmar or Lifebreath and watch youtube videos about HRV units, its something that is hard to describe in words but easy to describe with a picture.
acwizardUser is Offline
03 Feb 2012 05:10 PM
Depending on how tightly constructed this home is will help to determine the infiltration rate along with the required ventilation needed to keep the occupants safe from indoor air pollution.There is no way to determine without test equipment what the conditions are or just how much that 5" damper needs to be closed.Call a professional , it will be money spent wisely.
The ground freezes more than 4 feet deep, so I'm not sure how effective a ground loop would be.
People Online People Online: Visitors Visitors: 171 Members Members: 0 Total Total: 171
