Posted By concretekax on 20 Feb 2012 07:25 PM
Hi I am putting a large great room addition on our house and am looking at passive solar heat. I am wondering if anyone could point me toward resources to find true North at my house and to find the solar path at my location. Once I know this then I need to find what size of awnings I need to shade my south facing windows in the summer. Any on-line resources for figuring this all out?
Mike
During the winter, stick a thin metal rod or wood dowel ~3' high in the ground where it can receive direct sun from the south. Use a spirit level to make sure that it is vertical. On a sunny day from ~11:00 am to ~1:00 pm (wide range of time selected because it depends on where you are located within your time zone for solar noon) precisely mark the tip of the shadow ~every 10 minutes. Measure the distance from the rod to the shadow marks and identify the one that is shortest. This represents the sun's highest point in the sky. A line drawn from your rod to the shadow mark closest to the rod represents true north within a few degrees.
Alternatively, if your local newspaper has sunrise and sunset times for every given day in your area, the middle of these two points will be solar noon. Using the vertical rod, mark the shadow on the ground at solar noon. This will represent a true north-south line within a few degrees.
Another option is to use the NOAA solar calculator here:
http://www.esrl.noaa.gov/gmd/grad/solcalc/
