I am in the beginning stages of building a new house, and i am trying to plan out all of the details of how i would like it to be constructed. I feel it would be worth an extra expense upfront for a better built home, one that is better insulated and more comfortable to live in. But i cant afford to just throw money at it, it needs to be cost effective as well. Here are some of my thoughts so far, if you have any comments or suggestions please reply with them.
I already have another thread going that covers the
insulation questions i have and how to address them
Drain tile installed along the side of the concrete footer, wraped in filter fabric sock, burried in 18-20" of 3/4" clear gravel, topped with filter fabric and backfilled with dirt to grade level.
Another thing i read online is to install a concrete "wedge" at the exterior point where the foundation walls sit on top of the footer. It seems like it would channel the water flowing down the foundation wall and direct it towards the drain tile. I figure i could just mix up a few bags of concrete and form in a small 2" triangle with a trowel. Think this would be worth the effort and minimal cost?
Use AdvanTech moisture resistant floor decking, wall sheathing and roof sheathing. I checked at a local building supply warehouse and the cost on these is pretty much the same as regular old osb, so this is a no brainer and not much of a cost adder.
I am tossing the idea around of using 2x10 floor joists at 12" on center instead of the standard 16" on center. That or would it be better and/or cheaper to use 2x12's with the 16" on center spacing? My goal here is to try to stiffen up the floors and to help minimize/eliminate floor squeaks. I am also planning on either have the carpenters screw the floor decking down, or if they charge too much for that, just doing it myself after they glue and nail the decking down.
Use OSI Quad synthetic rubber caulk for ALL exterior caulking.
Use Air Vent Shingle Vent II ridge vents. And i will install a wire mesh animal guard at the vents.
I would prefer to use pex tubing for the plumbing lines in a home run setup, instead of copper lines. I wouldn't think this would be much of an extra charge. More material, but cheaper on the installation might make it a wash.
Use a 60 gallon hot water heater, and i will buy an insulating kit for it after we move in. I'm still not sold on tankless water heaters. Have heard of the problems that some of them can have, and some don't perform as expected. Can anyone talk me out of the std hot water heater???
Would the house wrap go on the wall sheathing, or on the foam?
Install 1x4 firring strips to mount the vinyl siding to, and to act as a rain screen. What would be a good and cost effective product to use here? Std wood boards, plywood ripped into strips, cement board ripped into strips? Also the guy at the local building supply warehouse said that they now make a exterior house wrap that has built-in dimples or channels that act sort of as a rain screen. Has anyone used this type of product (said it is only a few hundred more for a whole house), or would it be better to pay extra for the firring strips?
Any help or suggestions would be greatly appreciated!
