"Green" Log Homes
Last Post 01 Jul 2012 06:47 PM by whirnot. 5 Replies.
Author Messages Informative
21 Apr 2012 08:40 AM
If I was going to build a Log Home .....this would be it- http://everlogs.com/product_everlogs.php
GTJONUser is Offline
22 Apr 2012 02:57 AM
IF GeoThermal with 100% HW Priority full heat recovery, consider the ground-loop 2-Tons over-sized from a system-unit design nearer an 85% of the heat-load design, for quotes.  A smaller GT in a larger Log Home with a Mini-Split may be much better, if the GT makes all your HW.
MikeSolarUser is Offline
06 May 2012 05:37 PM
Not much green about concrete. Very high embodied energy.
www.BossSolar.com
ICFHybridUser is Offline
08 Jun 2012 11:12 AM
Uh oh. A heretic.  ;-)
It's long been argued back and forth whether concrete is ultimately considered "green" or not, but it is a very sustainable building product. I don't think it is fair to characterize it as "not much green". You can get LEEDS points for using it. It is very durable, so it extends the life of structures and there are a number of energy conserving properties it contributes to construction. It can serve several functions at the same time such as structural and decorative. It is also produced locally almost everywhere and incorporating fly ash which is a waste product instead of Portland cement can significantly reduce the "embodied energy".
09 Jun 2012 08:39 AM
Posted By ICFHybrid on 08 Jun 2012 11:12 AM
All true, but firstly, I don't give a lot of credence to LEED anymore, some yes, but there is no LEED points for solar so it can use improvement.
I know it is difficult to do a building without concrete and i don't advocate a total ban on it. Far from it, but if, for example, you could do a stacked stone wall (in areas where stone is given away, Nova Scotia, for example) it would be more "Green". My biggest problem with concrete is the gravel pits that are usually at the head waters of the waterways we use for fresh water. It destroys them and the filtering is VERY important to farms and small towns.
www.BossSolar.com
whirnotUser is Offline
And it is recyclable.
People Online People Online: Visitors Visitors: 311 Members Members: 0 Total Total: 311
