Bringing ductwork into envelope
Last Post 12 Jun 2012 04:00 PM by Dana1. 3 Replies.
geekUser is Offline
12 Jun 2012 11:55 AM
I am planning on putting an air handler and ductwork in my attic to handle heating and cooling to my 2nd floor.  As part of the same project, I am adding insulation throughout the house.  My attic runs the full length of the house and at the peak is about 7' high.  In order to bring it into the envelope, I was thinking of doing the following:
-Flash and fill the floors to airseal (going back and forth about open cell vs. closed cell for this application) and use lots of cellulose to bring up the R value
-Sprayfoam the ducts with closed cell foam (I've read that open cell won't hold up to the vibration)
-Build a box around the air handler with EPS or XPS foam and make sure one side could be opened for access to filter, etc.
Some questions:
1-Is this a good idea and if so, what are the code issues I need to be aware of?
2-Do I foam underneath the ductwork and airhandler or just around and on top of since the point is to allow it to be part of the envelope?
3-What moisture and access issues should I pay special attention to?  I've seen air handlers in attics that have drip pans but if I insulate properly, I don't know if this is still in issue.  Also, if I'm putting all the ductwork under foam, it does make it a little harder to get to in order to repair or make any manual airflow adjustments, I presume.
12 Jun 2012 12:26 PM
The cc foam on the ducts needs an ignition barrier to meet code. IIRC 3" + of cellulose would qualify.
In a vented attic with air-permeable cellulose, the underside of the duct is still going to be colder than the outdoor dew point in humid climates, and will experience condensation if it doesn't have air-impermeable insulation on the underside as well. (Whether the cellulose would adequately buffer that depends on the climate and the cooling load, but fully insulating the ducts is more assured.)
geodudeUser is Offline
12 Jun 2012 02:31 PM
I have done this exact thing before. In retrospect, I would have pushed for a foamed in unvented attic. It just performs better. On another note that drip pan is a secondary pan in case the internal condensate pan fails. Most codes will require this for an attic unit.
If there's any way to bring the ducts & air handler fully inside the conditioned space (or go ductless) it makes sealing the attic/conditioned space boundary easier and more reliable, and presents far fewer headaches down the road.
By the time it's said and done it's sometimes cheaper & better to do as geo-dude suggests, make the roof deck the pressure and thermal boundary of the top of the house rather than the attic floor.
People Online People Online: Visitors Visitors: 253 Members Members: 0 Total Total: 253
