Posted By MSG79 on 29 Aug 2012 06:04 AM
Thanks for the responses.
I do plan to build it myself (be my own GC) but I'm still a few years away. I hinted that I would hire a PE in the end, but I want to make the calculations myself first. I just don't know what the code requirements are for steel beams. For example, for wood beams the code says something like the ends of the beam must have at least 1.5 inches resting on the supports. I'm wondering what that would be for a steel beam. I'm also wondering what would be the requirements for anchoring the beam to the supports. There is nothing in the IRC that talks about it. I'm an electrical engineer, so once I complete my current move (I'm in transit between assignments) and pull out my old ME college text "Statics and Strength of Materials", I figure I can come pretty close on the calculations. I was just hoping for some guidance/specs from the code to give me a little direction.
I would recommend that you join the Engineers Forum:
Engineer Tips ForumThe forum is for Engineers and one must prove they are an engineer to even join the forum. Since you are a EE, you are eligible and there are many PE on the forum that would answer your question much better than any of us here. I am not an engineer but do read their threads and they know what they are talking about and offer a lot of insight.
This forum is more geared towards general practices and green energy stuff, your questions are more of a PE nature and would be better suited there.
What made you chose ICF?
