Air sealing and insulating recessed can lights
Last Post 29 Sep 2012 08:35 AM by greentree. 6 Replies.
strategeryUser is Offline
29 Sep 2012 01:46 AM
What's the best approach to air sealing and insulating these recessed can lights? I have IC rated LED recessed lights. I was told the best way is to build a foamboard box around them, taped at the seams, then spray foam around the bottom of the box where it sits for a good air-tight seal. I've also seen some caps that fit right over the lights but I've never used them.
What do you think?
29 Sep 2012 03:18 AM
Ideally one would NOT want to have recessed lighting in an attic space. It creates air leaks and energy holes. I would make sure that the canned lights are the type that can be sealed. If not, then you might have to get different canned lights.
I am sure others will chime in with their advice...
29 Sep 2012 03:29 AM
I have LED recessed lights.
I see your point about creating a hole for air to leak, but it's a small penetration so shouldn't it be easy to air seal?
29 Sep 2012 03:43 AM
Posted By strategery on 29 Sep 2012 03:29 AM
What kind of insulation is inside of your attic? Are the canned lights buried in this insulation or exposed?
29 Sep 2012 03:52 AM
Well the two recessed LED lights I have now have foam boxes (taped at the seams, sealed to the ceiling plane with spray foam) over them and there's a lot of blown insulation up there, some of it covering the foam. Both cellulose and fiberglass, blown in. I was thinking about doing another LED recessed light in the spare bedroom and I was asking about this in case someone had any better ideas than a foamboard box.
greentreeUser is Offline
cost effective approach is Insulite boxes, could also use Tenmats but they cost more. I used to build foam boxes but state energy program does not support that. Could also use drywall or cement board.
People Online People Online: Visitors Visitors: 190 Members Members: 0 Total Total: 190
