Sounds like -25F would be a good design temp then, eh? If the heat loss calculation methods overestimate by even 10% (most do), and you sized the boiler EXACTLY for the calculated -25F load you'd sail through a sustained -35F without a problem. If you're 15% oversized for the -25F load it wouldn't give up any ground even at a sustained -40F. |
