Was there only condensation at the ceiling? Did the condensation extend down the walls at all? What were the outdoor temperatures when you started seeing condensation? I presume the nighttime lows are what was cooling down the stairs above that are exposed to the cooler temperatures. It was a valiant effort to seal off the space above the foam, but you just can't make it air tight unless you fully bed the foam sheets. There is going to be an air space that will exchange indoor air as temperatures change in the concrete. I have an ICF wine cellar, but the concrete within is insulated to the exterior because of the outer layer of foam. And, I live in coastal Zone 5 so lows just don't penetrate the ground as much as where you are. Depending on how the stairs slab is set up you might try and insulate the stairs to the exterior. You would drop foam sheets below ground level and use "wings" as if you were doing a frost-protected slab wherever you can. You would be trying to force a balance between whatever heat the stairs were getting from the house and what it is losing to the exterior. Of course, you can't do anything about the surface of the stairs, so that might be a losing proposition from the start. Here are some additional tactics to think about, in order of increasing expense, I hope. 1) Drill a series of holes through your foam sandwich and shoot canned foam up through them in an effort to seal your foam to the ceiling and reduce the airspace up there. You will want to place a series of 2X4 across the ceiling with braces jammed to the floor below so the foam sheets do not push away from the ceiling when the foam expands. Holes need to be smaller than the foam applicator tube so the foam doesn't flow back out on you. You could also get a foam gun with a long, rigid applicator wand to poke through. It's going to take a lot of holes and would best be done in the summer when it's warmer and, presumably dry up there. If it's wet, you could try sealing up your room and put a heater in it in an effort to force the condensation plane back out the concrete for the application. Might take a case or two of foam cans. 2) Take your foam sheeting down and apply a thick enough layer of spray foam to vanquish the condensation plane. I hope you have adequate moisture barrier on the exterior of your foundation. Again, you would need to do this when the surface is warm enough and dry enough for the foam to set and grab, although, with the foam down, you might have a better chance with the heater in the room scheme. I like Foam It Green from Guardian Energy Technologies. A 200 board foot kit runs about $400 and a 600 board foot kit is about $700. I don't think you could pull it off with the smaller kit, because that will only give you about 4" of foam on the ceiling. That *might* be just enough, but I suspect you are going to want to go down your walls a bit, too. They also have a 400 board foot kit of "high density" foam that is about $750. It has a bit higher R-value and might get you enough coverage including down the walls some. 3) Someone like Dana1 will have to tell you how much foam you will need, but 8" on top seems like a bit more than might be required. The reason to go with self-applied foam is that the foamers I know won't even set up for less than $1,000 or so. |
