Broan HRV or ?
Last Post 05 Nov 2012 12:02 PM by esger. 2 Replies.
hausfxrUser is Offline
05 Nov 2012 01:27 AM
I'm about to purchase a HRV for my basement.  The basement is well insulated and sealed with ICF walls, mostly below grade, hydronic heating, and will not have much of a heating load at just over 1000 sf.  It is a separate apartment from the main house.  I'm considering a Broan HRV90HS, mostly because of its low cost and wanted to see if anyone had an opinion on Broan or could recommend a better brand/model in the same price range - $600 plus wall control panel and bath timer.  HVI rates it pretty average on efficiency, but a primary consideration for choosing this model are the ports out the front and back.  The HRV will have 3 exhaust vents, with the largest in the bathroom, so it needs to be powerfull enough to take 80 cfm min. from the the bath.
3cityblueUser is Offline
05 Nov 2012 10:08 AM
If the unit is located in the basement living space and not just ducted from there, I would place a higher premium on how quiet it is all other things being equal.
Good point 3cityblue. The unit will be locacted in the utility room, but it will be attached to the ceiling, so noise to the second level will be an important consideration.  Broan seems to consistently state their sones for the HRVs as "information forthcoming", which tells me they might not be the quietest models or else they'd be marketing sound levels the way they do for their fans.  I did a Google search for sones on Broan's HRV and could not find anything - plenty of ratings for fans.  But feedback about Broan's overall performance and durability are what I'm really interested in.
People Online People Online: Visitors Visitors: 282 Members Members: 0 Total Total: 282
