Source for underslab vapor barrier
Last Post 13 Nov 2012 08:31 AM by Gary Olsen. 5 Replies.
BirdmanUser is Offline
11 Nov 2012 11:46 PM
I'll be pouring a basement slab shortly and am looking for a good source for vapor barrier material. I'd like to avoid regular polyethelene sheet (regardless of mill thickness) as I've seen too many 15 or 20 year old slabs come up with deteriorated sheet under them. Anyone have a good source? I'd prefer to just order it on line but can't seem to find a supplier.... Thanks
ICFHybridUser is Offline
12 Nov 2012 02:07 AM
What material are you proposing to substitute for the poly sheeting?
12 Nov 2012 03:23 AM
Tu-Tu by Sto-Cote Products, Stego Wrap or SlabShield are some options.
One contractor I talked to said plastic vapor barriers for a slab-on-grade in Arizona are a waste of money. He pours his slabs directly on raw compacted earth.
arkie6User is Offline
12 Nov 2012 07:18 AM
You want something that meets ASTM E-1745 standards.
I used Americover 10 mil vapor barrier under my basement slab. I ordered mine online and had it delivered to work which has a loading dock.
http://www.americover.com/10_mil_vapor_barrier_761_prd1.htm
13 Nov 2012 06:03 AM
Right. I want to meet the ASTM 1745 - which garden variety 6 mil poly doesn't. The Americover looks good to me with a perm rating of 0.14 - pretty close to being a vapor barrier (<0.1) That should do it - thanks!
Gary OlsenUser is Offline
Check out http://www.barrett-inc.com/thebarrier.php
I did not see ASTM 1745, but it may comply and be something for you to add to your list of possibilities.
My interest is in the radon reduction.
People Online People Online: Visitors Visitors: 122 Members Members: 0 Total Total: 122
