Posted By Lee Dodge on 13 Dec 2012 10:32 AM
Posted By Dana1 on 13 Dec 2012 10:15 AM
In most of the cooler parts of the US if you avoid smoking & VOCs you can run the HRV via dehumidistat control to keep it a comfortable & healthy 30-35% relative humidity @ 70F
I would modify that to say "...in most of the cooler parts of the eastern U.S. ..." In the dryer parts of the western U.S., the HRV would rarely turn on if based on humidity levels rising above a set point.
It depends on the volume to occupant ratio, and whether the occupants bother to bathe, eh?
High house volume/occupant ratios can become a drying issue at high altitudes over the course of a winter, independent of ventilation rates. But at high volume/occupant ratios in a low-VOC environment backing
WAY off from ASHRAE recommendations for typical homes does not present a health issue. Some ultra -tight PassiveHouses use a combination of dehumidistat & occupancy sensor input to control ventilation rates to guarantee a minimum, but breathing & bathing humans put out a lot of humidity in the course of 24hours, and hitting high CO2 levels before the interior humidity hits 30% RH @ 70F in a hermetically sealed enclosure isn't very likely unless breathing is the only moisture source. (Buy some houseplants, and water them, eh?)
