Tankless 4 years old, Green water when doing flushing
Last Post 23 Dec 2012 11:21 AM by johnny1720. 2 Replies.
johnny1720User is Offline
22 Dec 2012 10:14 PM
I have a Paloma Tankless hotwater heater. I installed it in May of 2009. I really like this unit even though it is only 85% efficient. I have been flushing the unit with a pony pump and distilled virgin vinegar per the manufacturers instructions every 18 months. Today while I was flushing after an hour or so, the water turned green. The water in the bucket that I was recirculating was clean except it was green. Is that normal?
sailawayrbUser is Offline
23 Dec 2012 11:12 AM
Acidic water flushing causes erosion in copper piping (and copper heat exchangers) which results in the water having a blue or green color. If you are properly following your manufacture's instructions for flushing, you should be OK.
Yes I called the MFG and they specifically said only to use virgin white vinegar. The inline filter was clean as a whistle and the vinegar solution seemed to be rather clean.
Thank you for the reply....
People Online People Online: Visitors Visitors: 313 Members Members: 0 Total Total: 313
