Pea Gravel on TPO
Last Post 17 Feb 2013 04:57 PM by whirnot. 3 Replies.
whirnotUser is Offline
12 Feb 2013 09:01 PM
Because we are planning a modern design with flat and low slope roofs the roofing of choice seams to be TPO as it has a much smaller environmental footprint than PVC.
The issue with either of these being aesthetics.
With the sloped portion being visible, I am considering covering the roofing with pea gravel similar to they way they used to do it with built up roofs. Other than the obvious weight that has to be considered, anyone and experiance that this would be detrimental? We are in a primarily heating climate (5) but the roof will have full exposure since we are passive solar oriented.
acwizardUser is Offline
13 Feb 2013 07:56 AM
This thought process is not advisable.You are paying for a top of the line roofing material and then you are wanting to damage the product by adding pea gravel.
Kevin_in_DenverUser is Offline
15 Feb 2013 03:15 AM
TPO can be ballasted, according to Firestone: http://www.firestonebpe.com/roofing/ultraply-tpo/systems/ballasted-system.aspx
Pea gravel is smaller than what they recommend. It tends to travel down to the gutters easier than larger gravel.
Passive Solar House, built 2004, ongoing solar thermal experiments
Yeah, scratch that idea, in order to keep it in place, there would be issues. and ballasted rock is smooth, pea gravel may not be. Will just use colored TPO.
People Online People Online: Visitors Visitors: 192 Members Members: 0 Total Total: 192
