Posted By Estrogen Hostage on 05 Aug 2013 12:15 PM
Also I'm not a huge fan of foam in homes. I've become less so after starting the project. I saw the foam under my concrete smoking where the metal flashing reflected the sun onto it. I don't really want something that prone to fumes or fire on my home.
Are there other sheet insulation products that could do this?
The
high density rigid rock wool panels available are
well suited to this application. From a cost point of view it's a
significant uptick from EPS or polyiso, but it's completely fireproof, and has very minimal outgassing from the binders used (the vast majority of which get cooked off in the process of manufacturing the panels.) The compressive strength isn't as high as the mid & high density foam, and the weight is 4-5x that of foam, but it works, and works well.
