apples and oranges. the spray on wrap is in place of Tyvek, not insulation. Perhaps he's planning to use interior spray foam for air sealing? If so, and without getting into the pros and cons of that, I'd say to do whatever you are planning to do on the interior and utilize this exterior spray for a good exterior water and air barrier. "Insulated siding" as in vinyl insulated siding? The "insulated" part is a good way for the vinyl manufacturers to increase their sales dollars, but a waste of money as far as insulating your house. Buy the standard uninsulated siding and put your money into better insulation, either inside or outside. |
