leave basement uninsulated for one winter
Last Post 22 Oct 2013 04:06 PM by eric anderson. 4 Replies.
AlexisUser is Offline
22 Oct 2013 01:54 PM
Hello, do you think it's a good idea to leave the basement foundation wall uninsulated for one year. I plan to insulate from the inside, and I'm affraid that by covering right now the foundation with insulation board I will not be able to repair small crack that appear in the foundation. Of course, I know I will pay more heating this winter for the ininsulated foundation, but it's almost 7' deep so it shouldn't be THAT bad. It's my experience that a lot of new concrete foundation cracks initially because of shrinkage or initial settling... what do you think of this idea? Alexis
22 Oct 2013 02:09 PM
Leaving it uninsulated on a higher-R building would increase the design condition heat load by quite a bit, and a heating system designed for the uninsulated peak could be grossly oversized (at a cost in efficiency & comfort) for the "after" picture. But it all depends...
If you go uninsulated, size the mechanicals for the post-insulated loads, and use auxilliary heat to stay warm during the coldest bits.
22 Oct 2013 03:48 PM
I'm curious, is there really a need to repair small cracks in a concrete wall?
Bob IUser is Offline
22 Oct 2013 03:56 PM
no reason that I know, except if there is water coming through the cracks, which rarely happens with good drains and a good tar coat on the exterior. I'd insulate it immediately.
Eric AndersonUser is Offline
No reason to delay insulating the walls. If you have our drainage and waterproofing right it is a non issue. If you don't, on year is not going to help. Cheers, Eric
