artesian well convert energy to cottage
Last Post 21 Nov 2013 10:36 AM by joe.ami. 12 Replies.
Author Messages Informative
paul doverUser is Offline
17 Nov 2013 12:27 PM
we have an artesian well beside our cottage very close .the well is set back from lake 250 feet on a sloped hill .the wells temp is 45 degrees  we have a 1 inch supply from the casing cap it is pushing out 5gallons a minute .i would like to convert the energy to ac in summer and heat in winter.will a heat pump work
17 Nov 2013 01:25 PM
You can use a heat pump for open loop geo thermal heating/cooling and of course you will get more flow out of it if you add a pump. There is a little bit of energy in the height and pressure of the water, but I don't think you will be able to extract enough to be worth it (see micro-hydro).
Bob IUser is Offline
17 Nov 2013 02:34 PM
No way to know. You'll need to contact a company that does geothermal, or an engineer, and ask them. They'll need to do a heat loss study of your house and calculate the amount of water needed to produce the correct number of btus. Then they can figure out if your well produces enough water and has enough storage to do the job.
18 Nov 2013 08:34 AM
At 5 gpm and 45 degrees, the well would support about a 2 or 2.5 ton geo heat pump. That is assuming water quality is adequate.
Other storage or soaker options would allow it to augment larger systems.
20 Nov 2013 08:00 AM
the cottage is 1000 square feet  i think a 1 ton heat pump maybe okay
20 Nov 2013 08:04 AM
the cottage is 1000 square feet do you think a 1 ton unit would work the cottage is well insulated.
20 Nov 2013 08:12 AM
the cottage is 1000 square feet .the water quality is good  a little iron content but very clear .would the cottage use 1 ton or 1 1/2 ton btu to cool and heat i am trying to learn if this is possible thanks   paul dover
ICFHybridUser is Offline
20 Nov 2013 08:16 AM
20 Nov 2013 09:13 AM
You can try it to get a pretty good idea. On a very cold night, do you find that three 1200 watt electric heaters (ie, 1 ton) are adequate to keep the place warm?
20 Nov 2013 09:58 AM
Lest we forget 1 ton systems may not deliver a full ton in heating season depending on entering water temperature.
Paul, what you propose maybe doable, but there's alot for you to learn.
20 Nov 2013 06:14 PM
hi joe as i stated before the water temp stays at 45  all year long  can i use a heatexchanger .in winter it can get -30 c    the  water is at 45 f   .now when we leave the cottage on sunday i would like to heat the on from heatexchanger so when we come to cottage on friday nite i hope the cottage will be at 45f now i will leave on baseboard heaters on slighty for back up  we have a wood stove to heat up fast on friday nite . i am trying to get as much info so i make the right move thanks paul
20 Nov 2013 09:35 PM
IMO, the best energy investment for a cottage is a system that uses air to blow water out of the pipes so that you can easily leave the place (or most of it) completely unheated. And a foundation design that allows freezing. Maybe something to start heating the place up before you arrive too.
Again Paul designing starts with a load calc. If you want to make your cottage 45F how many btu's will that take? If you don't start there no one can help you. 45F will likely rule out water to air, so you will be looking at a more sophisticated water to water system.
People Online People Online: Visitors Visitors: 388 Members Members: 0 Total Total: 388
