I have researched insulation for months asked on several forums, have bids from multiple contractors... I can't make a decision. My local design temperature is -4. I have an outdoor wood boiler bought to heat my run down 4500 sqft home.
My house is OLD and crappy. EST 1830s that has haphazardly been added on to up until the 2000's
I am essentially keeping the first story and ripping the second story off all new windows, doors, siding etc, have redone some of the house (1/3) that is almost entirely new except a savable piece of the old foundation. I need to make a decision on insulation. I am living here for the rest of my life so its important to me that this is done right.
- I KNOW that closed cell spray foam is great insulation HOWEVER I fear the moisture issues that it can cause, especially on old/new hybrid construction. Its also extremely expensive. I do not believe that spray foam insulation contractors are out for the best interest of the homeowner with their bids, they cover absolutely everything possible (rather than pointing out where foam is helpful and where it is not) and they don't KNOW how to mitigate moisture issues in the cielings for example (IE icicles coming out the soffit vents)
- I KNOW that fiberglass is less than ideal and should be avoided because there are so much better options.
Some problems:
I have scissor trusses making a vaulted cieling. This unfortunately was a bad decision as far as thermal efficiency goes. I only have 8" or less at the pinch point where the truss rests on the sill. My contractor neglected to mention or offer "Energy Heels" to allow for more insulation. Is this is a big deal? how should I approach insulating this cavity?
Moisture mitigation: I am avoiding spray foam because the old house meeting the new house repairs etc. Plus I am doing my own HVAC so I don't think I can afford an HVAC air exchange system that is required with spray foam
Does anyone have any suggestions for a COST EFFECTIVE insulation choice that I won't regret in energy losses?
Thank you very kindly for your help in this.
