New Construction Air Sealing
Last Post 15 Jun 2014 10:10 AM by BadgerBoilerMN. 21 Replies.
SurfsupUser is Offline
31 Jan 2014 05:34 PM
1.5in is about the most I am comfortable doing. I have a 80ft wide lot with 10ft on each side required to be left alone, and I have about 6in margin for error. They are anal here about where the finished siding winds up, not concrete. So I don't want to get close to the limit. Yea I know a 1/2in doesn't sound like much but I don't want a problem. The villages here are extremely anal. For the wall, I will likely spend some time on air sealing, then 5in of ocSPF with the smart vapor retarder. For the cathedral 14in TJI roof, I think I will do this: put tyvek on TOP of the rafters before the roof sheathing goes on, then blow 11" of ocSPF to that, and use the smart vapor retarder on the underside at the rooms and drywall over that. I'm being told by people around here this is more than sufficient. The Tyvek will prevent the sheathing from sticking and ruining the foam should anything weird happen.
BadgerBoilerMNUser is Offline
Interesting thread. I am just finished a pole barn, having sheathed the inside fastening 1/2" of Thermax just behind the steel from ground to ridge vent and taped. I have the inside framed with 2x4's and a cavity to fill roughly 6". It appears the best solution is for R-value, sound and price is a dense pack such as Optiima.
