Seems to be a lot of confusion revolving around this
concept. I’ve been doing some research, talking to ONRL and Texas Tech I
thought I share my notes thus far. I’m in search of the most robust
design-build green net-zero disaster resistant (tornado, hurricane, earthquake,
fire) home to date.
Steady state R-values don’t apply since thermal mass is
acting as a hot/cold storage vehicle. The complex thermal dynamics equates up to
several dimensions of flow. The computer models will try and simplify to one
dimensions. The new metric is DBMS (Dynamic Benefit for Mass Systems) that
gives mass walls a comparative r-value to lightweight construction. ONRL
(BTRIC) has a calculator based on three house prototypes in 10 climate zones.
http://web.ornl.gov/sci/roofs+walls.../index.htm
So basically, thermal mass is all about loading/unloading
hot/cold concrete from a source such as the sun or HVAC systems, preferable
from the sun a free renewable source. The biggest bang for the buck are in
areas where the temp fluctuates diurnal(daily) temperatures of say 50F with
respect to the internal building set point. Mass performs equally well in hot a
cold climates if the walls are able to load and unload.
According to a 2001 ORNL hot box test a CIC (Concrete
Insulation Concrete) due to the above out performed ICFs (ICI),
“This
data shows that the most effective wall assemblies were walls with thermal mass
(concrete) being in good contact with the interior of the building (Intmass and
CIC)”
SCIP (Structural Concrete Insulated Panel) is CIC and
despite myths that a thermal bridge is created by the metal W-truss there are
test and utility bills to the contrary.
3rd party test and OEM info: http://67.205.102.169/~trabajos/gul...-approvals.
You can easily perform such test yourself.
Contrary to popular believe ICF (ICI) by insulating the
ability to load and unload performed much worst in the ORNL hot box test as
seen by low DBMS value in the graph, http://web.ornl.gov/sci/roofs+walls...igure4.pdf
“Wall configurations with the concrete wall
core and insulation placed on both sides of the wall (ICI)/ICF performed
slightly better than Extmass (foam on inside) configurations. However, their
performance was significantly worse than CIC/SCIP and Intmass configurations. “
Due to day/night temp fluctuations the
ICF/SCIP walls performed better in hot climates, not cold like popular believe
has it.
“The
most favorable climates for both wall systems were in Phoenix and Miami and the
worst locations were Minneapolis and Chicago”
Click
“conclusion” on left/bottom,
http://web.ornl.gov/sci/roofs+walls/research/detailed_papers/thermal/index.html
Conclusion, the most efficient predictable wall is CIC/SCIP
with constant DBMS in adequate delta “T” climate zones. Thermal
loading/unloading concrete drive weight/thickness/size design criteria with
respect to passive solar gains that determine HVAC and structural load requirements.
Other References:
http://web.ornl.gov/sci/roofs+walls/AWT/HotboxTest/PCP/Metal&Concrete/index.htm
http://www.bibm.eu/Documenten/ECP%2...%2009).pdf
http://www.rci-online.org/interface...gatski.pdf
http://www.homeenergy.org/show/article/nav/walls/page/3/id/1503
Texas Tech did ballistic testing on heavy mass vs light
weigh construction. The weight and speed of the missiles (2x4s) were determined
with a 220 mph wind and average projectiles speeds found in over 200 storms.
Light weight construction and wood SIPs don’t survive debris penetrate walls,
mass concrete walls shatter the missile. They tested helix added to concrete
(not noted) but it is hard to analyze since concrete cannot be penetrated. I would
think helix is not necessary although the thickness of the helix reinforced concrete
may allow less structural thickness if the thermal properties could be
maintained.
Concrete roofs are another unproven dilemma since most
storms such as Moore, Joplin, OK lost the stick roofs even with hurricane ties
from up lifting. Now rebuilding with eve vents to relieve internal pressures
yet to be proven. A monolithic roof/wall concrete design would make sense here.
Using the TX tech data in 90 degree wall ballistic and blast test one could
assume greater impact resistance from debris force with a sloped roof, less
slope, less force but, more snow loads and rain accumulations and perhaps
unappealing esthetics that come with low or flat pitched roofs.
References:
Ballistic Video: http://www.depts.ttu.edu/nwi/research/DebrisImpact/
ICF Blast Video: http://www.tfsystem.com/Benefits/DisasterResistance.aspx
http://en.mdue.it/files/2012/07/May...rt_ING.pdf
<!--[if gte mso 9]>
Normal
0
false
false
false
EN-US
X-NONE
X-NONE
