I'm looking for recommendations on cost effective ways to insulate a home that I recently purchased. The house is a modular home that was assembled in 1995. The ceiling rafters are 2x6 on 24 inch centers in the main portion of the home, and then 2x6 on 16 inch centers in the bonus room above the garage. The bonus room currently does not have collar ties installed which will be installed mostly to give me a nice flat surface to install ceiling fans and recessed lights. I'm trying to figure out the safest and best way to properly insulate a home like this without it leading to rot from condensation, etc.
I believe that the zone I'm in (Zone 5 a or b) requires at minimum, R38 for a cathedral type ceiling, please correct me if I'm wrong. I am contemplating adding 2x4 furring strips perpendicular to the existing 2x6 rafters on 16 inch centers, but the catch is that I'd like to install them with the 2x side touching giving a total rafter depth of 9 inches. I could also get by I believe with 2x2 furring and then install 2" xps foam board to the underside giving me a 7 inch cavity and a start of R10 with the foam board.
I would like to bring the entire attic roof assembly into the building as conditioned space. My main reason for that is ease of air sealing, not having to deal with insulating the kneewall, and because I have storage built into parts of the kneewall that would be tough to properly insulate.
As for insulation I've read so much regarding vented and unvented roof assemblies on story and a half homes, but there hasn't been a definitive answer on the proper path to take. If it's advisable, I'd love to use wet spray cellulose insulation in the walls and ceiling. I've had a few spray foam quotes for both open and closed cell foams, but they are fairly pricey and may not be in my price range.
Thank you very much for your help, I really appreciate it!
Here is a general outside shot of the home in question.
http://i.imgur.com/ItQjxHm.jpgThis is a photo of the upstairs main portion of the home with the existing collar ties. Rafters are 2x6, 24" on center.
http://i.imgur.com/sF85ffV.jpgThis is a photo of the upstairs bonus room above the garage. Collar ties will be added. Rafters are 2x6, 16" on center.
http://i.imgur.com/4wgSxB9.jpg
