Opinion on DAP Alex Plus All-Purpose Caulk
Last Post 05 May 2014 08:18 AM by greentree. 28 Replies.
greentreeUser is Offline
29 Apr 2014 06:54 AM
The point of sealing the stud bays is to stop air movement in the cavity. Its very hard to seal top and bottom edges of sheathing from the outside effectively. Field seams are a bit easier to seal. Building wrap does very little air sealing work as typically applied.
This is coming from a guy who hangs drywall ceilings and runs a pre-insulation framing blower door test which by the way I would highly recommend. In fact do it prior to any wall sealing but after your building wrap, you will quickly get the picture.
SurfsupUser is Offline
29 Apr 2014 07:56 AM
Posted By jonr on 28 Apr 2014 11:01 PM
With that on the inside and something (building wrap, taped OSB, taped foam) on the outside, you have two good air barriers and I don't see the point in using sealant in the stud cavities.
OK I'll think about this more thanks.
Understood. I'll probably run a bead across the sheathing joints and put tape over it before they blow in the cellulose anyway. I will probably have plenty of time to do so.
29 Apr 2014 11:20 AM
I suspect the the future of building wrap as an air barrier is something more like this.
29 Apr 2014 07:07 PM
I don't get it, there will be 1000s of nail holes in that building wrap shortly.
FBBPUser is Offline
29 Apr 2014 11:07 PM
Posted By greentree on 29 Apr 2014 06:54 AM
Insert house wrap between the top plates. Tape it down over the wall house wrap. Seal it to the ceiling vapour barrier.
04 May 2014 09:04 AM
Posted By FBBP on 29 Apr 2014 11:07 PM
That sounds like a good simple solution, but have you verified its effectiveness? Would also cost a lot in labor and tape. Using that method I would have issues with truss hardware, general punctures of the wrap and the questionable durability of wrb tape. Oftentimes some holes are made after siding is on which would make it impossible to seal at the plane of the housewrap. How much does this method cost and what are the results?
04 May 2014 09:11 AM
Surfsup: Most air barriers (OSB, interior poly, etc) get nails or screws driven through them. But a hole filled with a nail isn't really a hole.
Jon, I was referring to holes from mechanicals or plumbing.
People Online People Online: Visitors Visitors: 161 Members Members: 0 Total Total: 161
