Posted By Lbear on 12 May 2014 06:53 PM
Posted By Dana1 on 12 May 2014 04:47 PM
Both EPS and XPS tolerate water well and are fine to use under slabs. Polyiso does not, but is fine for insulating concrete foundations on the interior, but not the exterior.
Is there such a thing as reclaimed polyurethane and how does it tolerate water?
SFAIK polyurethane hasn't been widely marketed as rigid sheet goods the way polystyrene and polyisocyanurate have. While there are closed cell polyurethane SIPs out there, I've never seen polyurethane panels with thin (or no) facers.
At any given density closed cell polyurethane is more resistant to liquid moisture than it's chemical kissin'-cousin polyisocyanurate, but I don't know at what density you can bury it without issues. At 3lbs density it's suitable as roofing, provided it's protected from UV degradation by paint or stone ballast, etc., and I presume that's probably dense enough for sub-slab applications. People have used 2lb polyurethane under slabs but there are persistent rumors of problems with that. (I've yet to find any detail on what the problems were/are.) I recently mistook a 25 year old sample of a 1.5lb density polyurethane stressed skin panel as polyisocyanurate- they have a lot of look/feel commonality, but they do not behave identically in every aspect (derating with temperature being one major difference.)
