The HRV is unlikely to make much condensate in the summer. It takes a case where the dewpoint of the incoming air is a bit above the air temp of the house air. You can only rely on the HRV decreasing humidity levels when the outside air is drier than the inside air. In that case the more you run it, the dryer it gets. This usually only works in winter. You have to get your dehumidification from the geothermal system, or add a stand alone dehumidifier, or decrease the amount of moisture you are adding to your house. The moisture comes from cooking, showers, perspiration, and your HRV. The HRV is making the situation worse, you are admitting 105 cfm of moist outside air continuously. This may be more that the geothermal system can dehumidify Try as an experiment, turning off the hrv for a week and monitor humidity levels-they should go down . Post the results, and we can go from there. Eric |
