Posted By howtobuild on 11 Aug 2014 10:01 AM
Thanks for the reply! So i should be looking for someone who has a cnc router and who works on a varity of comosite materials? I'll definetly check out the site you linked me. I'm situated in Serbia at the moment so I might try my luck and see if any neighboring countries could do it. I have found someone supplying the entire thing but it would cost me around $15,000 euro. Thanks again for pointing me in the right direction.
My first thought yesterday when I saw this post was "polyester" (like others suggested). But I didn't post because it's not that simple because you need a sphere to stick that polyester on.
A huge styrofoam ball but I fear polyester instantly eats that away.
You need to the sphere in half. Polyester is quite expensive. Add to that the paint etc. It will add up. likely not 15k but still...
The size may be a problem but what about a dome shaped polycarbonate skylight?
http://www.aiaindustries.com/circularskylightform.html
They sell at least up to 94 inch diameter http://www.aiaindustries.com/circularfullskylightform.html
They sell impact proof versions: http://www.aiaindustries.com/impactresistantskylights.html
Not sure they are strong enough but sure would be a good start to put polyester on.
