Modeling Mini-split heat transfer between rooms?
Last Post 10 Sep 2014 08:05 PM by Bob I. 60 Replies.
Page 4 of 4 << < 1234
Bob IUser is Offline
If you live somewhere with natural vegetation, there is moisture in the soil. Concrete is porous to moisture. here is how to fix it: glue down 1-2" of XPS or EPS onto the concrete floor, cover with 6 mil poly or heavier with all joints taped, lay strapping down then plywood for the floor. Install 2" fire rated Thermax on the walls; spray foam the joints and edges.
There are easier methods; this one works.
People Online People Online: Visitors Visitors: 292 Members Members: 0 Total Total: 292
