When you say "Brick Cavity Wall", what exactly are you referring to? Two wythes of brick with insulation in the middle?
2 parallel walls with a space between them.
The space usually is filled with some sort of insulation.
The walls are 2 structual brick walls.
Or 1 structural concrete wall and a non structural brick wall.
Brick is very labor intensive so new houses very often use concrete. In large projects with lot of similar houses the concrete is prefab. Usually with piping for electricity poured in the concrete. Bolted together. It's almost build as fast as the trucks can unload.
It's not thst I absolutely want that kind of construction. It's just what I know best. The 2 advantages I see in it are:
- The R value can be about anything because the cavity can be wide.
- About anything can be fastened to it without special fastening strips as with ICF.
Whatever I build it must be maintainance free. I want zero worry about bugs, rodents, moidt/rot, storm.
I'm sure I can find a contractor who builds according t my specs. But that may get beyond my budget. I just have the leave my old thinking patterns behind when immigrating.......
