Posted By Luke on 03 Jan 2015 01:15 PM
Hello,
I am in the process of building a new home. I am planning on having the home foam sprayed. My hvac contractor is trying to sell me a 17 seer unit which he says will eliminate the need for the fresh air ventilation unit.
Don't listen to your HVAC contractor he doesn't know what he is talking about. The SEER rating of an AC unit has nothing to do with it.
Mechanical ventilation is required in any modern air-tight home. The 2012 IBC requires it in new homes. The ERV/HRV unit should ideally be ducted on its own duct work but it can be done on existing HVAC duct runs.
