Magnesium Oxide Boards (Fail Critical Testing)
Last Post 14 Jan 2015 04:23 AM by MgO Corp. 8 Replies.
MgOCorpUser is Offline
06 Jan 2015 05:39 PM
Welcome to 2015: MgO Corps wishes to start 2015 clearly & openly expressing to all members the need to be vigilant & not blind or mislead about the quality & standards of mgo products you may wish to buy. During 2014 MgO Corp & our associated global partners carried out extensive testing which has led to our organization no longer accepting mgo manufacturer or suppliers stated performances of the products they make & distribute. Comprehensive test data proves that over 95% of mgo products are not suitable for the applications they are promoted & sold to the consumer for. WARNING: The SGS Accredited testing under the American ICC-ES Standards for use as an Exterior and Wet Area Lining (ASTM C1185/86) clearly ruled out the use of (ALL) Common / Standard mgo products !! That's correct, All High Quality Test Samples failed to pass all the ASTM guidelines notably water permeability. As a resulted MgO Corp has developed a full range of specific engineered "Fit for Purpose" products that have been fully tested & approved under all aspects of ASTM C1185/86, accredited by CodeMark & under ICC for use in all areas of building & construction in America, Australia, New Zealand, Malaysia & Sweden including Exterior & Wet Area Linings. MgO Corp over the past 6yrs has invested heavily into understanding all the characteristics & performances of mgo so as to firstly mitigate risk to our company & our clients and secondly to be able to deliver a product that will truly deliver the performances we promote to the best of its ability. The journey has been at times challenging, disappointing and upsetting to find out that the vast majority of magnesium oxide board manufactures, trading houses and on selling groups have absolutely no idea how or if their products will actually perform when applied in a building..... "Other than the worst mgo product will not burn" MgO Corp has found out the hard way also that the vast majority of supporting ISO & Testing Documents supplied by so called manufactures & trading houses are fake or been changed to show a result the buyer has asked for. The sales pitches out there are nothing short of confusing and many very misleading. From mgo board that suppose to exudes water vapor into the air to quench a fire (we would all love to see this. But it is scientifically impossible) • People claiming to be the founders of making mgo as a sheathing & patents over a process that has been around for a lot longer than they have. • Claims of structural performance just because five people can stand on a panel. • The list goes on (just don't be blinded by the slick salesman) Our advice to all consumers; Is to take 5 minutes and ring the appropriate 3rd Party accreditation authority as well as the testing laboratory & gain clear confirmation that the products you are buying are indeed genuine & approved for the applications you wish to use it in. The above is meant to open your eyes to be aware of what is really going on in the global mgo world and has been doing so unchecked for to long. Like any product you can get good and bad. Just be careful and be aware "that cheap can turn into expensive" when building. A Fully Accredited and 3rd Party Audited Magnesium Oxide Board Product that has all the Acoustic, Impact, Fire, Water, VOX & Structural Engineering Data will deliver to your next project amazing long term performance well beyond the traditional Gypsum, FC Drywall & you will enjoy a healthier and safer place to live and work for generations to come. MgO Corp can be contacted any time through our website if you require our assistance. www.mgoboard.com.au
tjetsonUser is Offline
07 Jan 2015 11:14 PM
love the idea of magnesium oxide board but it seems way to shady right now. Hopefully you guys can bring the quality control and standardization to it that you are wanting to. right now it seems the board is a sweet way for people in chinese to press industrial waste into a board and send it off to other countries and get paid for it
08 Jan 2015 06:42 AM
TJetson:
I thank you for your encouragement and MgO Corp can assure you and all readers our products do not require further advancements to out perform that of the traditional interior and exterior linings.
I must directly express against your accusations of products been made from industrial waist.
There is no industrial waist in any accredited mgo product manufactured by reputable companies anywhere in the world and I find your feedback comments are far from accurate and are misleading to readers that are seeking a clear direction on the advancements of what will become the future of building replacing the poorer performing plasterboard and FC products.
If one is to be constructive then factual comparative need to be raised to that MgO is an inert non toxic product compared to that of competing products that are manufactured using harmful calcium silica's and toxic resins as a main catalyst to their products.
Yet the consumer keeps buying these and seam to be completely oblivious to the long term harmful affects.
I guess that was also the case with major industry hiding asbestos from people until it was to late.
It is great to be able to say there is one thing the BIG END of town has made sure of and that is - any product that threatens their strangle hold coming to the market had to jump so many hurdles and meet so much regulations that there is very little chance unless it is the best to be accepted for accreditation in building and construction against FC, Plasterboard, Plywood, products.
TJETSON for MgO Corp to gain the level of government accreditations world wide has taken undying commitment and dedication that you possible could not understand.
But as the founder of MgO Corp I want you and the rest of the world to have access to these products because when they are of the highest accredited quality the use of mgo products will revolutionize they way we build. Our buildings will be safer, stronger, healthier & more sustainable.
Now that is worth fighting for in my book.
08 Jan 2015 01:06 PM
Posted By MgOCorp on 08 Jan 2015 06:42 AM
...when they are of the highest accredited quality...
When will that be?
08 Jan 2015 05:20 PM
Jelly
MgO Corps products are by far already the highest accredited, tested and approved mgo products available to global markets (Now)
I thought this was made evidently clear in the posts!!
MgO Corp is taking a position to make consumers like you to be aware that not all products are the same and you should only buy or use Building Code accredited, certified and approved materials.
08 Jan 2015 05:29 PM
Posted By MgOCorp on 08 Jan 2015 05:20 PM
Jelly
The problem with your posts is that they sound like a sales and marketing pitch and nothing else.
08 Jan 2015 08:00 PM
im gonna try mgo board once walls stop bleeding goo
11 Jan 2015 12:31 AM
i spent a day reading everything there is about mgo online and my take on it is: there is a lot of wack jobs involved in it and scammers
weirdos in florida trying to partner with indian bands slandering anyone else they can in comments on all social media sites.
medical marijuana growers from montana partnered with canadian indians in edmonton trying to build a plant in drydon ontario using free government money.
tons of chinese manufactures with pathetic quality control. Pump and dump stock scams selling Magnesium mine shares.
mgocorp, not to be a dick but looks like you have been pushing this for like 5+ years and its not going anywhere usually if you cannot get traction in a business after so many years its time to move onto something new
TJetson I don't know where you get the idea MgO Corp has gone nowhere over the past 5yrs. Our company has unlike others - just rushed the market thinking what everyone says is true on the performances of mgo. Quiet the opposite. We have been fully committed to the investigation of all aspects of mgo as well as gaining accreditation of our products under the guidelines of various countries building codes. This is a massive and time consuming process to say the least that has to be done if our products are going to break into the sheathing and flooring markets. Today MgO Corp has reached amazing milestones since February 2012 with our full range of products (not just 1 or 2) now accredited for use at the highest level of compliance to be used in building and construction in Australia, New Zealand, Malaysia, Sweden and all states of America. MgO Corp has associated partners now in over 20 Countries and been fortunate to work with some of the most exciting new revolutionary building systems that are entering the global markets utilising our ResCom accredited products. Each country has an accreditation and approval process has to be undertaken to assure our products meet that regions building codes. TJetson: MgO Corp is far from idle I can assure you
People Online People Online: Visitors Visitors: 201 Members Members: 0 Total Total: 201
