I am glad that you are concerned about what type of products you will be using in your new home. I am currently working on a presentation about green building and how it ties to what we build. I can tell you if you do the research you will be astonished. We build European Tilt & Turn Windows, doors, and cabinetry. My research was on PVC (Vinyl). Here is information for you even though you did not mention this particular product I feel it is essential information to anyone. The market demand for Green Building in rising and this is due to the rising cost of energy, code ordinance/regulations changing, and the availabilty and cost of green products. Some argue till they are blue in the face that green building is not becoming popular but they are wrong. More and more people are building green or trying to become more green. In an existing structure you are limited as to what you can do to be more "green." Windows and doors are usually the easiest.
Here is quick facts about wood. Wood products have significantly lower carbon footprint. It is environmentally responsible raw material, becuase it stores carbon. It is durable and can last virtually 100's of years with proper maintenance. It is structurally strong and natural insulator. For examp
le, radiata pine structural timber has a strength for weight ratio 20 percent higher than structural steel and four to five times better than non reinforced concrete in compression.
n•15x better than masonry
•400x’s better than steel
•1,770x’s better than aluminum
Why not PVC (vinly)
nThe lifecylce of PVC most environmentally damaging of all plastics. Production, use, and disposal results in the release of toxic chlorine based chemicals that are harmful to our health. These chemicals build up in our bodies, air, and food chain. They are known to cause cancer, hormone deficiencies, and immusne system damage. Now everyone everywhere has measurable traces of chlorinated toxins in their bodies, but we can limit our exposure by not using products that carry them. There are alot of European countries banning PVC products or are in the process of totally eleminating them. They realize the harmful effects. The new car smell when you buy a new car is from PVC products. Scary! Good thing I just bought a BMW. BMW, Volkwagon, IKEA, and Apple to name a few have done away with using any PVC products because they realize the harmful effects of this product. There are other alternative products that can be used that are not harmful. Wood windows get a bad wrap because people think wood rots,warps, has expansion and contraction, and there is alot of maintenance involved in the up keep. Well that is somewhat true. It really depends upon the wood used, finish, and the product itself. In our windows we highly recommend a wood called accoya. Look it up. I like to refer to it as the super wood. It has a 25 year in ground and a 50 year above ground unfinished! So imagine if you used a high quaility paint or finish. It does not expand and contract either like other woods. Yes there is a yearly maintence that will need to be done for your windows to last 35 years or you could do an aluminum cladding (be weary some companies do not make a good aluminum clad window), but you also have to do maintence to a vinyl window every 6 months clean, every 10 years replace gaskets and seals and then replace the whole window in 20-25 years. Vinyl is not structually as strong so putting triple pane glass is out of the question. Anyway, I could go on and on. I just thought I would share some information with you. Please feel free to contact anytime if you have questions or need some information about windows or doors.
