Thanks for the replies they are appreciated.
Yep arkie6 Arkansas humidity is a problem for sure and almost intolerable in mid summer. I think as a whole we are mid spectrum as far as U.S weather is concerned. It can get extremely hot but as a rule it is only for maybe 6 weeks or so out of the year. The rest of the year when temps are above comfortable is what I'm shooting for with the earth tubes. I plan to have a/c also. but hope the earth tubes with minimize the use of them.
sciguy yes the dew point can get high here. I'm thinking the mildew should be easy enough to control by spraying the intake occasionally with essential oil spray including tea tree oil or some such bacterial killing spray. There is a lot of benefit in my opinion to human wellness with essential oils. And they smell really good
And if worse comes to worse swabbing the lines could be an option. I've read elsewhere the advise to swab them at least once a year. But I know how that will go with me. Either I'll forget or procrastinate so i am hoping the spray will be sufficient. It just seems to me that earth tubes cannot be any worse than using a/c with the house closed up for 3 months or so out of the year with no fresh air coming into the house as most people do.
I do own my own backhoe which is a blessing so I can take my time and not be on the hourly clock and make changes if necessary but of course would rather get it right the first time.
I've found info on duct sizing and maximum airflow, earthtube wiki's, some project's done around the world etc. What I am hoping for is information on desired length, depth and optimum airflow for this area and soil type. So far I have found no definite's or even advised info on this.
