See the section containing "flash and bat"
here and also
here (might work anyway). But my opinion is that this "cold sheathing and vapor barrier on the exterior" design isn't very good for your climate. Might also cause some ice dam problems lower on the roof.
If you use a riskier design, I'd pay attention to humidity and pressure (positive is bad in the Winter).
