General Forum - Residential
wireless zone controller for radiant floor heat
Last Post 29 Sep 2015 01:01 PM by
timsen
. 6 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
timsen
23 Sep 2015 04:42 PM
So far I found Uponor C-55 to be the only zone controller that works with wireless thermostats. Is anyone aware of any other products? I'm retrofitting radiant floor heat (staple-up) but need a controller for the actuators that works with wireless thermostats for the different zones. Thanks, Tim
BadgerBoilerMN
23 Sep 2015 08:27 PM
https://www.forwardthinking.honeywell.com/products/zoning/zoning_products.html
timsen
24 Sep 2015 12:52 AM
I can't find any controller on that side. Are you sure they have anything for radiant floor application? So a controller where the actuators and pump are connected?
-Tim
chrs
24 Sep 2015 02:16 PM
Many wireless thermostats interface to whatever you are controlling the same as any other thermostat. So you can connect them to whatever system you would have used otherwise same as a wired thermostat.
Are you using zone valves or multiple circulator pumps? Do you have a particular thermostat in mind?
timsen
25 Sep 2015 11:10 AM
I'll be using 8x zone valves and 2 pumps
chrs
26 Sep 2015 09:32 AM
Here's a basic wiring diagram for zone valves. You can do it just as shown, except that each "thermostat" gets replaced by the receiver half of whatever wireless thermostat you choose, and the wires that say "to aquastat" actually go to a circulator control relay, like a taco SR502
http://s224.photobucket.com/user/JeffPicks/media/tstat_wiring.jpg.html?t=1243979754
I recommend taco "sentry" zone valves, by the way, because they consume much less power than any alternative I've found. And an ECM pump like grundfos Alpha or Taco Viridian VT2218
timsen
thanks!
Membership:
croccohvacusa
People Online:
