Thank you (everyone) for the help. It's looking like I'll have to use duct mastic over the seams due to potential movement of the underlying sheathing. I know many contractors that say that a Zip System roof deck doesn't need expansion gaps, but since the manufacturer's manual indicates that I should, I assumed there would be movement and added 1/8" gaps anyway.
Posted By Dana1 on 15 Oct 2015 04:42 PM
Duct mastic over tape seems to work well with almost any facer. Can-foam between the seams doesn't really cut it, but an always-flexible polyurethane caulk might go the distance (or not)
Dana1, when you say "Duct mastic over tape seams" do you mean that I should tape the polyiso and then apply duct mastic over it? Or that I should apply duct mastic where the tape would otherwise be used?
A few other questions for anyone:
1) I'm assuming that I should apply the stuff to both edge faces of the 4x8 sheets, butt them up to each other, fasten the polyiso in place, and then apply it over top the seams?
2) Is it OK to use duct mastic in conditions of high humidity (I don't mean rain) or should I wait for a dry and sunny day?
3) How much should I use at each seam? I don't know what the consistency of the material is, but should enough be applied so that when the two sheets are butted up to each other the duct mastic is squeezed out of the seam?
4) Should the duct mastic be fiber-reinforced?
5) Should I air seal the inner sheet of polyiso or the outer sheet? Or both?
Thank you
EDIT: The product I am looking at is Design Polymerics 1030 Duct Sealant, and it says it is "Recommended for sealing connections on flexible duct or fiberglass duct board." Would the fiberglass facer on the polyiso be similar to fiberglass duct board?
