I've got a radon issue, and we've recently had a membrane with active depressurization installed. That helped, but the house is 80 years old, the crawlspace is leaky and difficult to seal (cracks and irregularities), and there's still some radon. In the basement and crawlspace the radon is around 3 or 4, and in the kitchen on the main level it's around 2.5 - so it's not off the charts, but it's higher than I'd like for working at home. We'd also like the basement to be safer.
I'm considering an inexpensive ERV to exchange air in the crawlspace. I don't really care if it's an ERV or HRV... it's just that I see this affordable thing on Amazon (
Panasonic FV-04VE1) and I figure it's inexpensive enough that maybe I'll experiment. Not that I'm made out of money - I just don't want to breathe radon all day. I'm in Western CO at about 6,000 feet.
The house is 1200 sq. feet on the main level, and the crawlspace is maybe 800-900 sq. feet. With this thing exchanging 10-40 CFM, that seems adequate.
The question: is this a reasonable approach to further reducing the radon levels? We suspect that the imperfect membrane installation is part of the problem, so I'm thinking I'd install this in the crawlspace (and separate the duct terminations by at least 10 feet of course). Assuming I don't
increase negative pressure in the house, could I make things a whole lot worse?
Or... for $150 more I could get an HRV. Instead of ducting it into the living area, I'd probably just leave all ducting/airflow in the crawlspace since that seems to be the source of the problem. The house itself is plenty leaky, although I have sealed the crawlspace as well as possible (sealed the rim joist to foundation and filled any visible cracks).
Thank you for any insight.
