Fantech HRV shuts off
Last Post 06 Jun 2016 11:10 AM by petregan. 7 Replies.
petreganUser is Offline
05 Jun 2016 03:13 PM
I have a Fantech HRV providing ventilation for my super insulated home. The unit has worked great for 8 months but is now shutting off at times for no apparent reason. It will start up again by itself but goes off again seemingly at random intervals. The display screen goes blank and the unit shuts down. It ran great all winter and we have just begun opening some windows as the weather allows. Any ideas as to what might be happening. Thanks
Bob IUser is Offline
05 Jun 2016 03:15 PM
you could call Fantech and talk to a tech. Do you have a central control? Sounds like it may be programmed to run under certain conditions.
05 Jun 2016 03:35 PM
Yes, there is a central control in the living room as well as 2 button ventilation boosters in the 2 bathrooms.
05 Jun 2016 03:47 PM
check how it's programmed; and/or call the Fantech Tech department - they can probably help.
chrsUser is Offline
05 Jun 2016 05:44 PM
The display screen going blank makes it sound like it's a control problem, not a problem with the actual unit itself. I agree that contacting Fantech is a good next move.
06 Jun 2016 06:55 AM
Thanks for the advice.
ronmarUser is Offline
06 Jun 2016 09:19 AM
Does the system use a separate control power supply/transformer or does the control panel get it's power from the main unit? Regardless of the source of control power, with the display blanking out, I would probably start looking at the control power supply and it's wiring. It could be as simple as a lose connection in the control power wiring...
good idea, I'll find out.
People Online People Online: Visitors Visitors: 267 Members Members: 0 Total Total: 267
