By "roof joists" do you mean "rafters", or are you talking about where the floor joists go below the knee wall? With a vented roof you don't want to block air movement in the rafter bays, but you DO want to block air movement from the mini-attic space under the floor of the room. What do you have in the slanted roof area for insulation? Plastic bags stuffed with insulation aren't likely to be an adequate air seal for the floor joists- it usually takes some half-inch rigid foam board foamed in place at the edges to truly seal them off. It can also be done with corrugated cardboard stapled then foam-sealed in place. You can leave the insulated bags in place to ensure that the insulation is fairly continuous. The floor of the mini-attic is usually the ceiling of conditioned space below, which needs to be air sealed (any electrical boxes, plumbing stacks, flues, recessed lighting cans all need to be treated appropriately), then insulated to R49 (for the US climate zone 4 parts of NC) or R38 (the climate zone 3 parts of NC.) Using blown celluolose works better than low density fiberglass, since it's inherently more air retardent, and it's opaque to infra-red http://www.greenbuildingadvisor.com/sites/default/files/images/DOE%20climate%20zone%20map.preview.jpg http://publicecodes.cyberregs.com/icod/irc/2012/icod_irc_2012_11_sec002.htm Compressing the R19s in place to 3.5" in a 2x4 studwall performs at R13, which is fine. (A low density R19 is basically a "fluffed" R13- it's the same weight per square foot.) Using half-inch foil faced polyiso is good- but air seal the seams with a high quality temperature rated foil tape (eg Nashua 324a, found in most box stores), and run a bead of can foam to seal the top & bottom edges to make it air tight. The air tight drywall with no vapor barrier is the right thing to do for he interior side of the kneewall. Be sure to caulk the bottom plate of the kneewall framing to the subfloor, and air seal all electrical boxes & wiring penetrations. Since the foil faced polyiso on the back side is a true vapor barrier, be sure to use only latex/acrylic paints, no vinyl or foil wallpaper, no alkyd paints on the interior side or it'll be moisture trap. The risk of trapped moisture isn't high in a kneewall, but there's no need to take even that low risk.
