Posted By dfvellone on 20 Sep 2016 10:45 AM
Ater posting a question regarding my wall assembly I was advised to use eps instead of xps for my sheathing insulation. Any suggestions regarding manufacturers?
Don't know why one foam is easier to locate than the other, but here is a good lead for you for almost any foam you might need.
www.UnivFoam.com
They are jobbers that use foam factories all over the country, so they can get small orders if necessary (without an argument from the factory) and custom cut your foam panels to any width, thickness and length you need.
I have found that most foam factories are only interested in selling directly to you if you buy BIG orders. Custom sizes mean BIGGER orders.
UnivFoam may only buy your small order, but since they buy all the time, the factory's do what is required with a smile.
Good luck.
