2x8 studwall with 2" foam on inside of sheathing
Last Post 31 Jan 2017 05:27 PM by Dana1. 7 Replies.
kenjlapUser is Offline
25 Jan 2017 08:52 PM
Any advice would be helpful. Building in northern ny, st Lawrence county. trying to insulate my walls better without putting foam on outside of sheathing as I want to use cultured stone on exterior. I thought about building with 2x8's 2 feet on center and then cutting 2" insulation to fit between studs. I would cut them a little small and use some cans of sprayfoam to fill. I would then stick r21 bats in to finish the job. spray foam here is $1 per aquare foot per inch. So it would cost me about 6k for 3 inches. I could do it my way for $3500 and a few days of my time. Not sure what my overall r value would end up or the condensation factors, but figure it would be better than the 2x6 16 on center r21 bat house I live in now. any thoughts and thanks.
Roger RUser is Offline
25 Jan 2017 09:04 PM
Ken, Check these people out for insulated foam board - they are fantastic. They will cut the foam to any length, width or thickness and they sell a variety of foam types and r values. They are jobbers, and work daily with all the major factories so your price is better than you can find anywhere, including factory direct and they can get the factories to do cuts that a one timer could not.
univfoam.com
lightspotUser is Offline
27 Jan 2017 03:49 PM
I would check if the insulated Zip system is available in your area: http://www.huberwood.com/zipsystem/products/zip-system-rsheathing
crabappleUser is Offline
27 Jan 2017 04:11 PM
Roger R thanks for the link, I am looking into a walk out basement.
30 Jan 2017 11:33 AM
Thanks for the reply with the zip-r sheathing. 1" is available in my area. Its a little pricey at $43 a sheet, but I like the idea of the foam on the outside for the thermal break so I'm going to go this route. I'm in climate zone 6. Is the 1" foam enough? And how should I insulate the rest of wall on the interior. I'm building a 2x6 wall, 2 feet on center with the 1" zip-r for sheathing. Thank you
30 Jan 2017 03:33 PM
Posted By kenjlap on 25 Jan 2017 08:52 PM
A cut'n'cobbled foam approach is risky, since maintaining the perfect air seal over time is next to impossible.
At 2" of foam you don't even have sufficient R-value of the air-impermeable foam to meet IRC prescriptives on the 5.5" batts. The IRC calls out R11.25 minimum on the exterior side of wall cavities for US climate zone 6. See TABLE R702.7.1 CLASS III VAPOR RETARDERS:
http://codes.iccsafe.org/app/book/content/2015-I-Codes/2015%20IRC%20HTML/Chapter%207.html
If you used polyisocycnurate it would meet the letter of the code per it's labeled R12, but on a performance basis not so much. Polyisocynurate has to be derated to reflect it's actual performance on the cold side of the assembly. In your county & stackup don't assume more than R5/inch, R4.5/inch may be more realistic during the months that count if it's in the Adirondacks at altitude. You're looking at a minmum of 3" of foam to make it work even from an IRC minimums perspective.
If you're going to cheat the R-ratio you might still be OK if you used a smart vapor retarder such as 2-mil nylon (Certainteed MemBrain) under the sheet rock, but making that air tight for the long haul isn't exactly assured either. Using 2" of closed cell spray polyurethane would deliver more assured air tightness, and would just squeeze by the IRC minimums in the table. But it comes with a substantial environmental hit from both the high polymer per R, and the HFC245fa blowing agent (a powerful greenhouse gas).
Using 2x6 framing with cut-in bracing for the structural strength, and 3" of any type of rigid foam on the exterior (seams taped, caulked to the framing inside each stud bay)and NO structural sheathing would be a better approach- cheaper too. EPS and polyisocyanurate are both blown with pentane, which is far more benign than the HFCs used for XPS or closed cell polyurethane. Using reclaimed roofing foam from commercial building demolition or re-roofing is about as green as it gets for foam insulation (the environmental hit has already been taken, you're just loading up the "benefit" side of the cost-benefit scale by extending it's lifecycle.) There are a number of vendors trading in reclaimed roofing foam in New England.
30 Jan 2017 07:50 PM
Thanks for the reply dana1. I really need the sheathing on the outside for my cultured stone, hence I was going to use the zip-r sheathing that someone else suggested. but your saying I would need 3 inches of foam on the outside to meet code? Any other ideas? thanks.
I don't suppose losing the cultured stone idea is in the cards?
Using 2x4 framing and R15 batts, with let-in bracing for structure and 3" nailbase panels for the exterior should work, with plenty of dew point margin. ZIP-R is just a thin nailbase panel, but engineered to have a minimum structural capacity suitable for walls. The fatter the foam, the longer the fasteners would have to be, and the lower the structural capacity. IRC 2015 code min for R value in zone 6 is 2x6/R20 + R5 continuous insulation, or 2x4/R13 + R10 continuous insulation. A 3" EPS nailbase panel would be rated R10 for the foam, a 3" polyiso nailbase panel would be labeled R15, but would perform more like R12 during the dead of winter, which is still fine.
If you want to go better than code you can go 2x6/R20 and still just make it for prescriptive dew point control performance with 3" polyiso nailbase panel, but 3.5" (of either EPS or polyiso) or more would be better, if 2x6.
https://www.hunterpanels.com/product-documents/hpanels/speciality-products/108-h-shield-nb/file
http://www.atlasroofing.com/download.php?uid=822
http://specs.duro-last.com/download?id=450&type=pdf&_ga=1.258584778.1991330774.1485901461
http://www.greenbuildingadvisor.com/articles/dept/musings/nailbase-panels-walls
People Online People Online: Visitors Visitors: 171 Members Members: 0 Total Total: 171
