ICF 6" New Home
Last Post 02 Feb 2017 06:03 PM by blue ridge. 6 Replies.
blue ridgeUser is Offline
29 Jan 2017 02:45 PM
Hello, I would like to have built in S.W. Va. Blue Ridge Mountains an ICF 6" @3000ft. I need help in pricing: The house will be shaped in a rectangle with a 12ft wrap-around porch. The basement will have one side open for a walk out on a slow grade hill. The other 3 sides will be below grade 30"X 70" with 10 ft walls. All services run through the basement upward. The main floor will be 30" X 70" with 10" walls. Th roof will be Stick with spray foam metal roofing. Sorry, I am unable to download a picture in attachments. It must be over 100MB...
30 Jan 2017 01:17 PM
Does anyone know of an Architect that would be able to give me an idea of what it takes to build an ICf 6" home? I have plans from a firm that gave me permission to use but these plans would need to be modified-- specifically the roof grade. I could E-mail the plans via a PM if possible. Thanks for any help you can give...
01 Feb 2017 06:48 PM
Anyone want to take a swag? I tried with the free quotes that is on the side of this page with no response. Thanks
jdebreeUser is Offline
02 Feb 2017 05:56 AM
Your question of cost is way too general to even take a guess at. Depending upon finish levels, around here it would run at least $125 square foot, up to the sky is the limit. You'll have much better luck talking to a local ICF builder.
02 Feb 2017 10:55 AM
jdebree thank you, that gives me a start. I was mostly interested in just the 30' X 70' with 10' high walls for the basement and the main floor to be built with 6" icf logix blocks.
arkie6User is Offline
02 Feb 2017 01:31 PM
A rule of thumb a few years ago was $12-$15 per square foot of wall area (including window and door openings) for ICF installed.
Thank you, that helps very much. Sorry to be a bore-ass but I have no experience with the build of an icf home. I know that I want one for our final retirement home. I will need to find a contractor who knows icf homes so that I can show the plan that an Architect has given me to use.
People Online People Online: Visitors Visitors: 388 Members Members: 0 Total Total: 388
