shallow frost free foundations
Last Post 15 Jun 2018 02:28 PM by DP55412. 4 Replies.
GaryOUser is Offline
12 Jan 2018 02:24 AM
I am curious about shallow frost free foundations. These are generally a thick foam form filled with cement that has no grade beams or other excavation, except plumbing and electric. Sometimes it is called a raft foundation. The vendors say the cost of excavation, form work, and removal exceeds the cost of a shallow foundation. Do any of you have experience or knowledge about this?
13 Feb 2018 01:48 AM
I prefer a complete frost wall. Better performance with minimal additional cost. 42" frost depth in my area.
13 Feb 2018 08:11 PM
With either option, look for designs that minimize thermal bridging (for example, from a footing to the interior of an ICF wall).
It's easier to build a FPSF with very low soil loading.
agagent3User is Offline
02 Mar 2018 12:26 AM
My sons and I finished one near Waterloo Iowa. It's 1080 sq. ft. and I have $11,480 in it which includes $4,500 for the concrete and labor to pour and finish the floor. I do not believe we saved a lot over constructing a stem wall but it was a convenient choice for us considering the limitations of the site. The big ticket items were Fox Blocks at $2,800; high density EPS foam $2,800. It cost me $1,220 for a plumber to put in the drain system and water supply.
DP55412User is Offline
Anyone heard of Legalett FPSF system with integrated floor heat (using air in a closed loop, instead of hot water)? I'm interested in the Frost Protected Shallow Foundation idea, and also looking into floor heat options.
Thanks!
People Online People Online: Visitors Visitors: 166 Members Members: 0 Total Total: 166
