One tank desuperheater
Last Post 23 Jan 2018 01:39 PM by ChrisJ. 5 Replies.
Author Messages Resolved
JoeHUser is Offline
21 Jan 2018 06:13 PM
I understand a two tank system is best for heating water with the geothermal system using desuperheater. However, I don't understand how the one tank system could have been working for me these past 25 years. Aren't I circulating cooler water from the desuperheater through my hot water tank that is "usually" at 120 degrees? I suspect the tank water is more often already hot, rather than trying to get hot. So, most the time the pump is running, I'm just cooling the water.
ChrisJUser is Offline
22 Jan 2018 01:20 PM Accepted Answer
You are circulating water at the bottom quarter of the tank so a lot depends on what the lower element is set to. There is always some stratification within the tank.
JoeHUser is Offline
22 Jan 2018 08:58 PM
That helps. Thanks
22 Jan 2018 09:49 PM
Your correct about not much benefit with one tank. 25 yrs is a long time, same water heater?
I just purchased an inexpensive electric tank(scratch & dent) to be the storage tank(non-powered)
RAM73User is Offline
23 Jan 2018 03:15 AM
does it pay to hook up a heat pump water heater to a geo thermal with a desuperheater?
RAM73,
I think it's worth it if you use a non-powered storage tank connected to the DSH. Then the heat pump water heater will be the finish tank bringing the water up to final temp.
That is the set up I am using.
People Online People Online: Visitors Visitors: 232 Members Members: 0 Total Total: 232
