Hi,
I am building a new small 1570sqft house near Allentown, Pennsylvania and my architect and mostly me think its a great idea to put R10 2" exterior foam on the exterior walls to avoid thermal bridging and have a very efficient and comfortable home. I would need to box out the windows and have extension jambs on door and windows and it is more work then not having any foam on the exterior. I have talked to a few builders and they all think its a dumb idea and the house will be comfortable with r21 2x6 walls. I will be using 2x6 walls + 2"xps foam which is around wall r31. It will cost me around $4,000 more for the foam and extension jambs and will do the work myself. I will also need to add furring strips to attached the siding to. I also will need a HRV to have fresh air into the house as it will be a super tight house.
What are your thoughts? Do the 2" foam or skip it? I will also be using a 2 stage electric heat pump with variable speed air handler and keep it around 72f or 73 in the winter and 68 to 70f in the summer.
