When to Replace a Water Heater?
Last Post 02 May 2019 07:52 AM by HelenLewis. 6 Replies.
MichelleAnaUser is Offline
01 May 2019 05:08 AM
AlexabartelUser is Offline
01 May 2019 05:10 AM
Typically, the life expectancy of a water heater is about 8 to 12 years. Of course, that will vary with the location and design of the unit, quality of installation, maintenance schedule and water quality. Find more information here https://iwaterpurification.com/best-electric-tankless-water-heater-reviews/
newbostonconstUser is Offline
01 May 2019 07:44 PM
When it starts leaking....
sailawayrbUser is Offline
01 May 2019 07:59 PM
Before it starts leaking... There are horror stories about water heaters that have had their bottoms drop out from corrosion and have then destroyed places. Perhaps drain and flush the tank to see what's in there and then make a decision.
01 May 2019 08:13 PM
Rolling my eyes....we all play the lotto to....
02 May 2019 02:13 AM
Not me...my luck is all bad...
HelenLewisUser is Offline
If your water heater is leaking, then that may potentially require replacement as well. If you turn on the hot water and you get it for a short period, the water heater has an issue. If it tastes metallic, you need to replace your unit as the water is becoming unsafe to drink. If any electrical appliance will make some noise, then you need to fix or replaced, depending on what the problem is.
People Online People Online: Visitors Visitors: 443 Members Members: 0 Total Total: 443
