Essentially Tyvek is an imperfect barrier system as you're creating penetrations every place you have to staple it. So what'll happen, with condensation, you'll wind up with rot around such staple penetrations unless PERFECTLY detailed. Granted, another option would be to do a full-field peel-&-stick. And again, you definitely want to consider exterior insulation for thermally breaking the wall. Otherwise you wind up with warm/cold spots coming through the wall. One of the reasons for the Zip+R is the thermal break it provides. Spray foam can be an air sealant, but it has to be detailed PERFECTLY. Otherwise, as it dries and sets, spray foam can shrink and pull away from stud bays. Hence using a system like Zip to handle your air sealing detail. Additionally, you could then get away with using a flash-&-batt setup in the stud bays. 2" of foam. Pack the remainder with Rockwool/Fiberglass. |
