bathroom heating
Last Post 21 Nov 2019 05:53 AM by Dilettante. 7 Replies.
Erica_LUser is Offline
13 Nov 2019 02:38 AM
First-floor bathroom with quite a big window. Wall insulation did not help, any other methods? The problem is the room is not a part of a house HVAC system. Please, I'll appreciate any advice.
newbostonconstUser is Offline
13 Nov 2019 11:40 AM
Mini Split? It is likely best to get some quotes from local HVAC companies. Can new ducts be run? Does the house have natural gas?
Blinds over windows can help also.
13 Nov 2019 08:58 PM
A mini-split would be INSANELY oversized for the heating and cooling loads of a bathroom.
To get to to the optimal solution starts with a reasonably careful heat load calculation. Even running an I=B=R type calculation using a spreadsheet tool can be pretty good, and WAY better than a WAG:
https://www.greenbuildingadvisor.com/article/how-to-perform-a-heat-loss-calculation-part-1
https://www.greenbuildingadvisor.com/article/how-to-perform-a-heat-loss-calculation-part-2
Or a sorta-reasonable Manual-J-ish on line calculator such as loadcalc.net...
... or a real ACCA certified online Manual-J tool such as coolcalc.com.
There are no short-cuts, and many ways of screwing it up using online tools. The I=B=R method approach, skipping the air infiltration portion (houses are much tighter than the assumptions in most load caluculations) would be good enough to get a handle on it.
Is there a pre-existing whole house HVAC system? Assuming yes, please describe it.
What type of water heater is serving this bathroom?
What fuels are available?
Is replacing the flooring a possibility?
A micro-zone hydronic solution running off the water heater is one possible approach using radiant floor, heated towel rack, small panel radiator, or baseboard can be right-sized for the design load & water temps.
Electric mesh floor heating under new flooring or electric panel radiator/baseboard is another.
elyssarob65User is Offline
14 Nov 2019 07:51 AM
Agree with Dana
hutbephot3mienUser is Offline
15 Nov 2019 02:53 AM
I also agree with Dana
My blog : https://hutbephot3mien.com
DilettanteUser is Offline
20 Nov 2019 07:24 AM
I three with Dana.
20 Nov 2019 11:47 PM
Not-me, Dana is actually an idiot- go ahead and ask his wife! :-)
I guess that's why we get along. The space between my ears only houses a Bronx Cheer generator....
People Online People Online: Visitors Visitors: 282 Members Members: 0 Total Total: 282
