Need help insulating over concrete
Last Post 21 Dec 2019 05:40 PM by smartwall. 7 Replies.
superbeeUser is Offline
16 Dec 2019 05:35 PM
We live in an older home (1940) that we purchased with 2 additions.  First addition in 1992 is approx 625 sq ft living room with 6" concrete floating floor.  Below living area is 2 car garage/walkout basement with I-Beams and posts.  There is no insulation below or above.  Living area is a 9' ceiling.  There is a vapor barrier/underlayment with laminate flooring on top. Cold radiates from the floor and is very uncomfortable and I'm sure inefficient.  This space has it's own heating/cooling unit that literally never turns off in the winter time.  My question is what is the best way to insulate this?  We've had several bids... From installing rigid foam insulation on top > subfloor > then flooring..  Installing rigid foam on ceiling of basement.. To framing the floor with 2x4 or 2x6 then spray foaming.
2nd addition is on opposite side of house master bedroom. 350 sq ft on top of concrete slab.  There is carpet foam and carpet on top of concrete slab.  Same issue. Cold radiates and the room gets very cold when doors are closed.
Any help at all would be greatly appreciated as we try to navigate through these contractors.
18 Dec 2019 12:03 AM
Do you have a ZIP code or other location information you can share? What makes sense in some climates may not in others.
Some pictures of what the garage ceiling looks like might be relevant too.
18 Dec 2019 10:52 PM
Zip code is 62002.  I attached a pic, could not attach a good quality one.  The ceiling has small layer of some sort of fiber bonded to it.
18 Dec 2019 10:57 PM
lj
DilettanteUser is Offline
19 Dec 2019 12:04 PM
So, just outside St. Louis.
You already have an internal vapor barrier.  So spray foam is kind of a no-no.
Especially since you have obvious signs that the concrete is still actively drying to the exterior.
Depending on the thickness of the concrete, maybe a couple layers of Rockwool Comfort-Board.
If you want to cover it with an air barrier, make sure whatever you use is vapor-open.
20 Dec 2019 02:25 AM
The concrete is 6". Would i add this rockwool to the ceiling or go over the concrete in the living space?
20 Dec 2019 02:51 AM
This is the living space.  There is a vapor barrier and laminate flooring.  The floor radiates cold air.  In winter we have to wear slippers it's so cold
smartwallUser is Offline
I can tell you what I did in a similar situation. I used some eps that I found on Craigslist and glued it to the ceiling with gun foam. Used 2x's for supports until the foam dried and then put another layer on going in the other direction. Simple especially with concrete. Be sure to foam the seams where they butt together. You'll have a seamless insulation system.
People Online People Online: Visitors Visitors: 125 Members Members: 0 Total Total: 125
